I have a 16hp v-twin that I would like to build a utility vehicle around. It has a 1" horizontal output shaft. What T A V will work with this amount of horse power? Thanks in advance.
TAV refers to a specific type of torque converter (torq-a-verter) with a back plate which is mounted to the engine & has a built in jackshaft for the driven clutch; there are a few different makes around but, most are only rated to 13hp; for 16hp, you'll need a minimum of a series 40 setup with a separate jackshaft, a little more work & a lot more money...
I was planing on having a F N R transmission as a jackshaft and a final chain drive to a live axel. A hydrulic caliper on rotor setup will provide the whoa power. The drive tires will be around 24" in diameter, but thats why I planed on the chain drive, to be able to tune the final drive.
Jake Parker
