What size go-kart wheels are best?
redsox985
PA
Sprockets don't climb hills, torque does. Ratios help but TC's and a torquey motor do the grunt work.
GreyhoundOfYerfDogs
Los Angeles
Somebody once asked Abe Lincoln how long a man's legs should be. "Long enough to reach the ground." was the answer. :thumbsup:
Small tires are for smooth roads and light karts. Large tires, especially balloon tires, are suited for rough terrain and off roading.
You will "gain or lose torque/speed" if you leave the gear ratio the same but change tires. Better to choose the tire according to the size and type of vehicle, and the type of riding you plan to do, THEN gear your kart accordingly. You can have the same off-the-line and hill climbing speed and torque whatever the tire size, if you design the correct gear ratio. :wai:
Larger diameter tires roll over obstacles more easily, absorb shock and avoid bending wheels and suspension better, and grip better in sand and gravel where smaller tires would quickly bury themselves.
Smaller, lighter tires are best for smooth pavement karts, where diameter offers little advantage and the extra weight affects takeoff speed and sometimes (where fractional losses count in competition) offer better rolling resistance and aerodynamic profile.
Use one of the online gear ratio calculators and see what playing with tire size and gear ratio does. :idea2:
redsox985
PA
wow i run 18's and they work fine(there old lawn mower tires)
and for street use old golf cart tires i think there 14'' or 15'' they work fine i only got a 9hp honda and i fly! :wai:
but i can go up hills like no ones buisness hmm must be ma sproket....:D
Grayhound, I was referring to his final bit of ingenuity on the last line. A 9hp Honda has some kick. I don't think ya sprocket is doin' da work!
drscope
Big wheels require big tires. Big tires require big $.
Choose wisely on your wheel size and investigate tire and tube prices before you commit to a certain size wheel.
Remember, tires wear out, so even if you find a good bargain going in, sooner or latter you will have to buy new tires.
redsox985
PA
Do you by chance have any affiliation with allied? They are linked in every one of your posts.
#28 FASTGRASS
Adelaide Hills, Australia
Free kart tyres
🥷 FREE TYRES we still get free tyres off light aircraft which fit on 6" rims for nil$ and they are more than happy to see them go. Check out your local small airstrip. great on off road karts....:cheers2:
