what size clutch
masterbusa2
Havent gotten fram yet just got engine today, its a subaru 9hp electric start, model# EX270D, I need to know what size chain sproket and clutch to get for it, Im not worried about top speed, but Iwill be takign it through thick grass, and a buncha pot holes xD, so I guess low end is what im worried about but top end wouldnt hurt and can anyone calculate speed with this motor and the clutch they specify:D tanks for all teh help guys
Nodroz
Belgium (Europe)
Measure the diameter of your engine's shaft. Then get back to us.
I assume it's either 3/4" or 1". More likely to be 1" since it's quite a heavy engine. A caliper works best to measure the diameter correctly.
If you have a 1" shaft, your clutch will be quite expensive, since it will need to handle all the power. Are you looking for a centrifugal clutch or Torque convertor?
masterbusa2
1" and idk which is cheaper? lol and btw, the motor goes counter clockwise soooooo when I put it on a go kart it will have to be backward right?
Nodroz
Belgium (Europe)
All of my engines that I have turn clockwise. Are you sure about that?
A centrifugal clutch is cheaper compared to a torque convertor. But if you have the money is it suggested to get a torque convertor since you will have more torque and speed.
See this post for the benefits and dissadvantages for both.
http://www.diygokarts.com/vb/showpost.php?p=214956&postcount=3
A clutch for a 1" shaft will be around $100 - $120. Depends on where you live though.
Nodroz
Belgium (Europe)
You will need a #35 chain and a 72 sprocket for on your rear axle.
You can change the rear sprocket according to the desired ratio you'd want.
masterbusa2
for more torque would I go lower or higher? and is there any way u can estimate speed based on sproket and clutch?
Nodroz
Belgium (Europe)
Yes there is a way: http://diygokarts.com/speed-calculator.html
If you want more torque, you'd need a bigger rear sprocket, thus having a higher ratio.
You will notice in the speed calculator that the bigger you take your rear sprocket, the slower your top speed will be.
masterbusa2
nvm just figured all tht out about 30mph and ima go with a 60 unless 72 means more torque, i wanna pull a sled if possible liek a car hood with a kid in it but I would need a torque converter for that kinda power huh?
my engine has 4000rpm limit ^.^
Nodroz
Belgium (Europe)
You will get more torque with a 72 sprocket, yet a slower top speed.
You can eliminate this slower top speed by buying a torque convertor. Only with this you will get full potention out of your engine. You will get good torque at slow speed and a nice top speed.
If you have the money, I would go for a torque convertor. There are many happy people with a torque convertor.
Nodroz
Belgium (Europe)
You pait only $75 for something that costs $560 new + it runs! I would say that was a very nice deal.
Another problem with mounting the engine backwards is your recoil start. How are you going to acces that?
If you're going to be driving through long grass & potholes (did everyone else miss that?), my advice is to use a smaller sprocket on the axle & incorporate a jackshaft. Yes, it will mean more money, more parts & more work but, the last thing you want to do is bottom out your axle sprocket; that could get messy. Not to mention what could happen if too much long grass gets caught in it.
What size tyres are you using?
Re: Engine direction. Pull the starter; what direction does the output shaft turn?
My engines all go counterclockwise as well.
lower gearing - more torque, less speed (higher number, eg 7:1)
Higher gearing - Less torque, more speed (lower number, eg 4:1)
You will have lower gearing, not higher. It does get confusing. The larger you make your rear sprocket, the lower you are gearing your kart.
Just be careful that you don't make the rear sprocket too big. If your tyres are small, the sprocket is going to be scraping on the ground
Nodroz
Belgium (Europe)
Just re-read the first post. He states that's it's an electric start. Seems like we both missed that part. :roflol:
Hmm, looks like I didn't read the first post carefully. Sorry.
I agree. If you're going for a centrifugal clutch, a jackshaft will be necessary.
To fabroman: will he also need a such a high ratio when using a torque convertor?
