what should i use (engine/clutch/tires)
If you're going to go with such a small engine, keep tire size minimal (say 13x5-6 max), keep size and weight to a minimum, and gear low.
If your budget was better (maybe wait and save your $) I'd suggest 11-13hp, a Comet40 CVT, and 18" turfs.
foggy34
that helps, thanks.
do you have a link to a place where i could buy the Comet40 CVT?
thanks
r_chez_08
Should be in the shop...
Cornwall, UK
What is your total budget?
I have a 6.5, comet 40 and 19" tyres, with a 6:1. Hauls on the flat, not so much on the hills.
You can get a comet 40 from mfgsupply.com
foggy34
i have the money, the question is how much i want to spend on this project, as i have many others (which make me money). btw i am 15 yo. with a drivers license.
i looked at the site, and there are like 20 clutches. if i got this engine
http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
would you mind linking a clutch and how i should hook it up, like sprocket size, do i do a direct hook up? or torch converter?
thanks
A CVT (torque converter) is a complete clutching and power transmission system. If you get one, do NOT get a centrifugal clutch. Not only is it NOT needed, it won't work. A CVT like the Comet 40 requires you to buy or build a jackshaft to mount the driven on, and then you would put a drive sprocket on that same shaft and run a chain from there to your axle sprocket.
dave1701
Good for 100,000 Miles
MICHIGAN
I agree. Some might think my big fat kart with a 5hp motor on it is slow, but I certainly don't. II get 30mph. It's got a 6:1 ratio with 15" tires and that leaves enough torque to go up any hill, bump or rut around here. I would save the money. Of course, I just might be captain slow...
