what kind of cable is this?
edgeblade
Here is my current set up but when I push down the pedel...the black cable comes out of the brass fitting
Sent from my SCH-I535 using Tapatalk
edgeblade
Different angle
edgeblade
Also the actual metal cable Inside the black sleeve, the diameter of the silver metal cable won't fit inside the aluminum part of the spring...I have to physically unwind strands of individual wire to make it fit...is this normal?
danssoslow
Louisville, KY
First issue, that's a 3/16" compression fitting. It's common to use as a cable ferrule when using brake line as the conduit. This doesn't necessarily mean it won't work if that black conduit is a bit thinner than typical brake conduit. First, unscrew the rear "nut" fromnthe fitting, and check to make sure that the compression ferrule is on that conduit. If not, you can find another ferrule at your local hardware store. If you cannot find the ferrule alone, buy another 3/16"x1/8NPT fitting, they aren't that expensive ($2-3 TOPS).
If the ferrule is there, make sure that the "nut" is on there tight. If it STILL won't tighten, you can apply a piece of electrical tape to take up the slack.
If that doesn't work (I doubt it will have to go this far though), you can try taking that black conduit (or a piece if you can afford to cut an inch or two off the length) back to the hardware store and finding a smaller fitting.
If you need a picture of that compression fitting, and the ferrule inside, just to make sure you can visually identify the parts, let me know.
Your other issue, any of those devices I have messed with are intended for a 7mm (IIRC) cable, a common size for karting. If the wire isn't frayed when you try to insert it, you may have a larger bicycle brake cable. Cutting a couple strands shouldn't hurt anything, as the throttle linkage shouldn't present a great amount of resistance. Keep any potential future fraying in check (maybe with a piece of shrink wrap), you should be good to go.
edgeblade
The black conduit is actually to big for the compression fitting...so I'm guessing I need to buy another bigger one
Where can I buy the 7mm iirc cable at?
Kingofwylietx
TX
If 3/16 is too small, the next size up is 1/4". Those things are cheap, and available at any hardware store.
edgeblade
I keep looking I tried to find them at our local lowes and at one of our general hardware stores intown to no avail...ill be driving down to a bigger city tomorrow that's actually has a true hardware store and check...if I can t find it tomorrow ill just order one online thx guys
danssoslow
Louisville, KY
That 7mm cable (don't quote me on the size) is available at any online karting store. It is the only aize I've ever seen available at any of them.
IIRC Stand for If I Recall Correctly :lolgoku: Nothing to do with the cable...
Hold up, 7mm is slightly larger than 1/4". Are you sure it's not 0.7mm? If so, a bicycle gear cable may work, they're slightly smaller than a brake cable (both the cable & the sheath)...
danssoslow
Louisville, KY
That's just it; I can't remember the exact size. The only reason I know (a very sloppy know) anything about the size is from searching for cables for my own kart. I found a site that denoted the cable size repeatedly. All of which, too, had that gas pedal "eye", like came stock on my Manco cart.
So the measurement is kind of a "put two and two together" kinda deduction. It fits those same type of fittings, and that site I found did sell one other size cable labled for bicycle brakes, and was a bigger measurement.
I'd put faith in finding throttle cable on any karting site will result in the right size cable. I wish I could remember that site, the cable was dirt cheap. 60+ inches was just a coulple bucks, and shipping was very reasonable; and it had that eye attatched, which makes attatching the cable to the pedal clean and simple.
Eef! How about this for a brain fart.
I found the diameter for the throttle cable, and its 1.2mm. How about that for an overshoot!! The numbers in my head were actually the CONDUIT sizes; 4mm for throttle, 7mm for the brake.
I apologize for the mistake. I hope the OP hasn't been trying to google 7mm throttle cable. That would be like using jacketed dog runner cable for the throttle. A little too beefy.
danssoslow
Louisville, KY
Meh, that's just what I do... not correct people (well, maybe sometimes) but, help... :D
It was definitely a correction in this instance; but very justified and necessary. I like this about this site a lot. All humans make mistakes. If someone is there to help you up, that's golden! Make no mistake; I'm more than willing to accept it! Pride can be a short cut from ignorance straight to stupidity. I accept being ignorant of many things; but I'll take all the advice in the world if it can keep from creeping into the stupid side of things! :D
edgeblade
Thx for the info guys...much obliged hopefully I can get this go cart on the road soon
danssoslow
Louisville, KY
How long is the cable? I cut one an inch too short for me to use, now it's useless to me. I may also have enough brake line to prevent you from having to buy different compression connectors. I have to mail a couple things out Monday, so I *shouldn't* take too long. If it'll fit your needs, I'll send it your way.
edgeblade
However now I have this to fix lol...I didnt realize my own strength...I found one on ebay for $28 and it should be here by this weekend....I was able to put both kill switches on two of my gocarts so at least I hqve something to show for the several hours I spent working on both of tjem today
edgeblade
Oh quick question the rotor the disc brakes attach to is it only held on by a key?...I didn't see any bolts holding it on ...but to get to the other side of the disc brakes I have to take the rotor off......
