What Is This?
OneTimeUser
We Don't Rent Pigs
Texas
All,
I'm no expert (by a long shot) but I know my way around small engines a bit. This engine, a Lifan 270 9hp has a little gizmo attached to the the exhaust that I've never seen and don't know the purpose of.
Do you?
It is the oblong gray pot-metal-looking thing with 16 small holes in it. It is connected by a welded tube to the exhaust pipe and sits at the rear-most part of the engine on the right side of the picture.
Any idea? Any clues?
If I change the exhaust to something sportier will the absence of this little gizmo matter?
Inquiring minds want to know.
And yes, I looked around quite a bit on the interweb before posting this question.
OneTimeUser
We Don't Rent Pigs
Texas
I'm waiting for an answer. This is new to me.
I wrote the Lifan engine company with the question below. We will see:
"I have a Lifan 9hp, which I believe is 270cc. There is a little oblong pot-metal part attached via welded tube to the exhaust manifold. It is grey and has 16 little holes in its side. Will you please tell me the purpose and function of this little part? Thank you? "
My first guess is something to do with some BS emissions crap. Any clue if this a California engine?
AI says:
The part you are describing is a Pulse Air Injection Valve (often called an Aspirator Valve or a secondary air injection valve), which serves as a mechanical emissions control device. [1, 2]
The Purpose and Function​
Your Lifan 9hp (270cc) engine is a Honda GX270 clone. To meet strict EPA and CARB emissions standards, manufacturers add this component to reduce unburned hydrocarbons (harmful exhaust emissions) without needing a complex electronic computer system. [1, 3]
It functions using simple physics:
  • Sensing the Pulse: Every time the exhaust valve opens, a high-pressure pulse of hot exhaust gas travels down the manifold. Right behind this pulse, a momentary negative pressure (a vacuum) is created in the tube. [4, 5]
  • Drawing in Fresh Air: The 16 little holes on the side of the pot-metal body act as an air intake. The vacuum pulls fresh, oxygen-rich ambient air through those holes and past a one-way reed valve inside the oblong housing.
  • Igniting Unburned Fuel: This fresh oxygen is injected directly into the scorching hot exhaust stream. The sudden introduction of oxygen causes any leftover, unburned fuel vapors leaving the cylinder to ignite and burn up inside the muffler before exiting into the atmosphere. [1, 6]
  • One-Way Protection: When the next high-pressure exhaust pulse hits, the internal reed valve snaps shut. This prevents toxic exhaust gasses and flames from shooting out of those 16 little holes.
Common Issues to Watch For​
Because this part is subject to intense heat cycles and exhaust soot, it is prone to a couple of minor issues over time:
  • The "Ticking" Noise: If the internal reed valve wears out or gets stuck open with carbon buildup, you will hear a distinct, loud ticking or fluttering noise. This happens because exhaust gases are actively blowing back out of the 16 holes.
  • Backfiring: If the valve fails or leaks, too much oxygen can enter the muffler at the wrong time, causing a loud pop or backfire when you decelerate or shut down the engine.
If the valve ever fails or rusts out, many equipment owners choose to cut the tube, remove the valve, and weld the hole shut (or install a standard, non-emissions exhaust manifold) to eliminate a point of failure. [2, 7]
To help you troubleshoot or maintain this system, are you experiencing any performance issues like backfiring or a ticking noise, or are you planning to modify the exhaust for a project?
[1] https://www.reddit.com
[2] https://www.youtube.com
[3] https://www.ebay.com
[4] https://www.cmpoparts.com
[5] https://www.reddit.com
[6] https://www.amazon.ca
[7] https://sdusdfamilies.org
OneTimeUser
We Don't Rent Pigs
Texas
Edwn,
Now THAT'S what I call a good answer. Thanks.
I suspected, as did Griz, that it was emissions related.
These days when I see something stupid my first thought often is "I betcha that has something to to with the US congress". I expect the Pulse Air Injection Valve lobby (AKA Big Valve) spent considerable time and money securing the mandate (and contract) for instance and production of this qizmo. The requirement for it is (without a doubt) buried deep in some 15,000 page Omnibus legislative bill passed in the last decade or so.
If a million single cylinder engines with this gizmo run at full tilt for a million years I expect it would mitigate the environmental impact of one good sized cow fart.
Glad you figured it out.
I was gonna tell you that its a PAI.
Leave it to the land of fruits and nuts.
Push fresh air in the exhaust for the emissions test just before the test point. Lol.
The engine still does what it does.
I say that just cheating the test.
You know what to do with it.. 86 it
Ersatz catalytic converter as I suspected. Have seen them before but they are not common. Open it up and let’s get a look-see. I mean it looks like it is serviceable (scrape out the carbon from time to time?) and I wonder if it makes a sound or affects the exhaust tone? Prob not.
Edit: maybe it hisses? 🐍
That is where the muffler bearings go. The bearings help cut down on noise and vibration. Master Hack has the ceramic muffler bearings in stock ready for immediate delivery. So act now! Only $79.99 each ball. Supplies are unlimited!
OneTimeUser
We Don't Rent Pigs
Texas
I have the muffler bearings on order, I'm just waiting on finding a good source for high grade pneumatic fluid and a gallon of prop wash.
Again I refer you to Master Hack. He has cases of prop wash and blinker fluid. Pneumatic fluid can be bought at any good hidrologic store.
