what is this?
iatemeself
Just picked up this go kart frame and slapped on a harbor freight 212cc on it, just order k&n dirt filter and adapter, candy cane header stage 3, got a gx140 emulsion tube and a 90 main jet, going to strip the frame and paint it red, remove the governor internally and install 18lb valve springs...
If someone can help identify what this go kart is it would be very helpful! Also need some help on where to find a throttle cable!
it has double bearings and was wondering how i could get the rust off of it the person i bought it from had it in the backyard over a tarp.. overall in pretty good condition i need to adjust the brakes and hook up the throttle,
jman231994
Australia
Not entirely sure I can help, but it does share some things with an old kart frame they have at my school. It has the dual pull caliper like that and a similar frame shape. Im not sure what make it is though but if nobody else knows I can have a look at it next week when my holidays end and try to find a sticker or something on it
bighead
Pacific Northwest USA
:iagree:
The brakes are like extreme bike brakes
Never seen them before I wonder if they are any good
For Mechanical brakes I think they would work well. You have the two long arms that gives you more/twice the leverage than a shorter single arm pull style.
Thats my thinking anyway.
qtband
St. Louis, MO
Put a wire wheel on a drill and do away with all that rust. Take everything off when you paint. Preparation is 90% of a good paint job. You can pick up a generic pack of cables at Walmart in the bike section for about $5.
The kart looks like it'll be a lot of fun!
iatemeself
thanks man just took it for a spin last night the ground was slightly wet and boy was it fun i was drifting around all over the place lol :drool5:
anyone got any tips on how to remove the rust from the axle, brakes, and steering components without damaging them? The brakes work well, however i think i need to adjust them to be tighter,
im about to take off the motor, remove the internal governor, oil sensor, do mild porting on intake and exhaust ports, 18 lb valve springs, im either gonna get the cylinder head milled .055-.065" OR use a gx140 cylinder head with the predator dowel pins and drill holes to fit them in the proper place and got the thinner .16 copper gasket vs .45 stock gasket, it has gx140 emulsion tube and 90# main jet which really woke it up, racing sparkplug, just looking to make this motor a mild engine with about 10-12hp have candy cane header #3, k&n air filter adapter, steel predator cam,
anderkart
Surprise Arizona USA
Your kart was made by an Italian company called Dino. You've got the model made for running dual engines. (that's why it has dual axle bearings and 2 motormount frame rails on the left side) I've got a Dino just like yours except mine came with the master cylinder/hydraulic caliper option.
The front spindles on your kart are from another brand racekart, they look like Biesse brand spindles.
It'll be tough to disassemble your axle with all that rust. I've got axles as bad as yours rust free and shiny again by securely blocking the back wheels up off the ground, and running the engine at a fast enough Idle to get the axle spinning, and then using long 2" wide strips of 100-grit Crocus cloth (metal sand paper with a super strong backing, available at most any good hardware store) to remove the rust just like if you were spinning the axle on a lathe. You have to be super careful doing this, dont get your fingers/hands close to anything. Use long strips and hold the ends like this pic below, and be ready to let go if the sandpaper gets snagged on anything.:
___________________
If you dont have any kart shops to buy a throttle cable, you can usually find bicycle brake/shift cables long enough to work just fine.
iatemeself
sweet that's some good news, do you know if the master cylinder hydraulic brake kit would slap on this? how would I set it up for dual clones? is this a good find for 300?
anderkart
You could probably get your old mechanical brakes working fine, you'll just need to clean/lube everything, and then use some sand paper to scuff up the pads and rotor surfaces to remove the glaze that builds up keeping them from getting a good grip.
I posted some pics of my Dino master cylinder and caliper, but I doubt you'll find any of the older/original style Dino brake components for sale in the USA. I already searched and struck out.
You could try contacting Dino karts in Italy:--> http://translate.google.com/transla...rts&hl=en&rlz=1T4GZAZ_enUS369US369&prmd=imvns
Or just do some mounting bracket mods and use aftermarket components:--> http://www.out2win.com/catalog/brake.html
You could even use some used motorcycle brake components to save money.
I think you got a good deal, from what I've seen these karts dont have any collector value in the USA, so I wouldnt worry about trying to keep them all original as far as using different brakes.
For a dual engine setup you'd need another motormount, clutch, sprocket/hub and chain.
iatemeself
Thanks a lot for all the helpful info :thumbsup: it seems like i would have to move the brake setup and get a different seat in order to fix the 2nd engine?
anderkart
Looks like maybe you could just instal a larger diamiter roller-wheel to get the cables wide enough apart to fit around a motormount.
Your old seat would be fine but you'd just need both motormounts that locate the engines further outward. The Burris Adjustable Mount Kit here: http://www.out2win.com/catalog/mount4.html are made to do that.
iatemeself
what do you mean by larger diamiter roller wheel and out of all those motormounts which would do the job for a predator 212cc
ALSO im using a wire wheel on a drill and its taking a lot of the rust off really quick, going to take off the engine and clean up the rust from the frame
Jcotz
...wasn't there
NY
Even though it seems like you really know what you are doing, if you remove the governor and put in heavier valve springs, nothing is stopping the engine from over-reving. So be careful with that,
anderkart
I was talking about that round thing your caliper cable wraps around.
I found some different motor mounts that would give you more side to side adjustment,
they also cost less: http://www.doverpoweronlinestore.com/catalog/item/8223865/8971772.htm
Those will fit your engine for sure, you just need to measure your frame rails like the info says to be absolutely sure it'll fit both sides of the kart. I think you'll need adjustable mounts on both sides to fit your seat.
kendelrk
redneck engineer
westland michigan
i dont know if youve noticed yet and its sure to upset you, but that adaptor is a tight fit, i had to grind down mine to clear the fuel shutoff
