I'm in the process of getting my engine to run when I found this nasty stuff. I was cleaning the carbuator when I found this orange mushy stuff all in the bottom of it. What is this?
I would just wipe the float off. Maybe put a little gas in a coffee can and wash the float a bit. As for all the other bits of a carb, carb cleaner is fine. If you hit some plastic just wipe it off quickly.
Now thats a nasty carb. Wipe it out as best you can. My guess is you will need new seals for at least the bowl judging how bad it looks. (if there is a seal left!)
Make it clean, you dont want that stuff clogging up the jet.
Besides cleaning the carb I'd check and make sure your gas tank isnt all rusty/dirty inside and make sure you've got a good fuel filter (or strainer) to help keep this from happening all over again.
Yup. One of the best solvents for rust and corrosion.
Carefully blow dry with low pressure air hose.
Jets can be cleaned with acetone and fine wire.
Paper stripped off of bread ties works well.
