T3clay
346cc predator engine, hose that goes from air filter to OHV its a larger hose big around as my thumb? What do I do with this when I upgrade my air filter?
That is to let the gas that seeps through the rings and piston to have a place to go its called a crank case breather .Most people just take it off but you can put a catch can on https://www.google.com/search?tbm=i...A%2F%2Fwww.krcracing.com%2Fgocart.htm;360;146
Here is what they are rumored to do http://oilcatchcan.com/
Oil, not gas
Well, you're both correct... & you're both wrong:
It's a crankcase vent & it's there to equalise crankcase pressure; it's connected to the air filter box so that any fumes don't escape into the atmosphere.
You can either buy a spacer that has a hose barb on it which goes onto the carb before the new air filter adaptor, then the hose connects to it, or simply connect a fuel filter to the end...
Cam, it's not necessarily gases escaping past the rings, it's more the movement of the piston, which creates vacuum & pressure, depending on the stroke; the crankcase vent allows the engine to move more freely...
Paul, there is a microfilter in the rocker cover which is supposed to trap any oil; if oil is coming out the crankcase breather/vent hose, either the engine has too much oil or the filter is full/dirty...
