If your currently going 0-40 kph in 2 seconds on 11 wheels, firstly wow, but secondly convert some of that acceleration into top end speed.
At the moment you're riding on a 1:5 gear ratio (14:70) try, 1:4 or maybe even 1:3, however if you're using a centrifugal clutch at that speed and gear ratio I'd be careful, and really consider a torque converter.
Alternatively try a bigger set of wheels, maybe 15 inch. That way you can keep your gear ratio as the bigger wheels will reduce acceleration but increase top speed. Also bigger wheels means a nicer ride.
Consider both, and a torque converter as most centrifugal clutches can't handle that power.
