Russ2251
AZUSA:Powered by LAWN-BOY
If you cut the keyway the same depth as the key, key won't do anything except fit flush with PTO surface.Russ i'm confused by your statement that the keyway is half the size of the width, which if the keyway is 3/16" would mean that the distance from the top of the shaft toward the center would be .09375". But then you said that there square, meaning it would be 3/16" x 3/16"
It's supposed to fit into clutch as well as shaft, or half and half.
Doesn't apply to width.
