What grit for a rebuild?
jman231994
Australia
Hey guys,
I'm finally gonna get the new seals for my Victa and some gaskets in the morning (hopefully). Just wondering about what type of sandpaper i should also get to clean up the surfaces before putting it all back together?
I've heard that the correct thing to do is put wet and dry on a piece of glass and then rub the head and cylinder etc on it to smooth it out. That all good?
And what grit Wet n Dry should i get?
And if anyone out there who's worked with a Victa could give me some pointers on getting the blade boss off I'd really appreciate it.
Thanks, Jordan
sideways
Unfinished projects king.
Perth, Western Australia
Hey guys,
Thanks, Jordan
I only ever clean the surfaces up with a wire wheel, sometimes I use super fine sand paper or a fine file to remove any imperfections.
I use glass and valve griding paste instead of sand paper, works well.
The blade boss is a b!tch. I've found the best way is to use 2 ball pein hammers and hit opposite sides of the boss at the same time. I hope that makes sense. It's only held on by a taper so yeah.
Thanks
Hayden
redsox985
PA
I would wait for Russ to weigh in as, IIRC, he runs (or knows how to run) an engine entirely with out gaskets just by polishing the surfaces.
jman231994
Australia
Thanks.
Me and my friend did all the surfaces with 800 grit wet n dry and it looked great. Fitted all the new seals and gave it a clean.
Piston and cylinder have no scoring at all and I think it has an oversize piston aswell. Im guessing thats what 020 on the crown of the piston means?
I think we set the points wrong cause it's got no spark now which really is a pain after putting it all back together. To top it off my starter needs a rebuild. Gives me something to do I guess.
And the two hammers trick worked. My friend told me that one aswell. I was surprised when it popped off haha
Thanks for the help
Bluethunder3320
IMO find a electronic upgrade for the points and one, you dont have to set it, and 2, its more reliable, and 3, you can rev it MUCH higher.
jman231994
Australia
I've actually got the electronic module for one of the newer victas but I'm not sure if it will work with it let alone how to connect it all up
sideways
If you've got a dead power torque you can use the cdi of that, I can post a diagram on how to do it if you want?
I can't remember what the points gap should be off hand but it's easy enough to set by eye. Test the capacitor and see if it's dead, they usually die and then burn out the points. No idea what you should torque the flywheel nut to, no one knows! lol
020 does indeed mean an over sized piston, 20 thousands of an inch overbore of course.
Bluethunder, the CDI wont make it rev any higher, the rev limiter is built into the coil, the way you make a Victa rev is to hook a car or motorbike coil (at which point, you will need a battery) up to the points or replace the coil with a very early model one (hens teeth). :thumbsup:
Thanks
Hayden
EDIT: ahh, i see you replied about the power torque ignition whilst i was typing.
Bluethunder3320
oh, i get it. no victas over here. the governor is built into the coil?
i put a electronic module on a tecumseh h60 a few days ago and the spark was very good and it was weak before, and seemed to get worse as i adjusted the points, until all of a sudden there was no spark at all.
sideways
There is a secondary governor built into the coil, it kicks in at about 6000RPM (like a Briggs or Honda would float the valves, that is their secondary governor). The primary governor is either (depending what carb you have) a tube that takes pressure generated by the cooling fan to a diaphragm in the carb, that diaphragm pushes the throttle slide closed when pressure is great enough. The other (old) kind is simply a wind vane attached the top of the carb.
De governing a Victa is as simple as taking a pipe off or snapping the plastic wind vane off. The better way to do it is just to replace the crappy carbs with something better.
All Victas are governed to 4000RPM by the carby gov.
With your Tec, you were probably increasing the points gap too much, charge builds up whilst the points are closed, the spark occurs when they open. But of course, CDI makes you life easier. :thumbsup:
Thanks
Hayden
jman231994
Australia
Good News. I found the correct gap on the net. It's also 20 Thou. I thought it was 25 when i got my dad to set them for me, but now its set to 20 and starts 3rd pull or so after a good prime. It's still a bit smokey but the smoke is blue now and in a quantity I'm used to seeing from an older two stroke so she's all good.
Carby is a bit glitchy and only lets it run for 10 seconds or so but I've got a walbro for it anyway so the g4 is fine for test runs. Ironically I actually lost the little clip on mount for the governor tube and was hoping it wasnt anything important hahahahaha.
I'll try and get a video of it running up later in the week.
One last question, what exactly is it about the crank seals that makes the engine smoke when they wear out?
Thanks, Jordan
