What do you think
kartin-nick
Hi
How fast do you reckon a kart weighing around 15 kilos, with 30cm wheels, 16 teeth on the motor and 45 teeth on the axle, powered by a whipper snipper motor would go.
Thanks :auto:
rameses32
I don't mean to be a party-pooper, but I don't think it will go at all, thats a pretty high gear ratio, Fairly tall tyres and a pretty weak motor, not a good combination. Throw in a bigger motor and you got something. Most whipper snipper motors are 38cc or less and you really need something over 150cc. I have a 49cc pocket bike and you have to push it to get it goin.
Charley
Hi
Thanks :auto:
Kaptain Krunch
Pro Junk Collector
vermont
Charley
CC has nothing to do with HP my 100cc dirtbike engine that i put on my kart is around 10hp, has a ton of torque and will go up any hills, my 5hp tecumseh is 200cc but is half as powerful.
However you are right, with a whipper snipper motor you wont go anywhere, the clutch will slip or the engine will stall.
ed1380
Banned
ATL, GA
the tec is an industrial engine. those are 3600rpm max but it has as much torque as the dirtbike engine
rameses32
Ok, if we are wrong then you should be looking at a cart that will go 130kph, go for it and let us know how it turned out.
ed1380
Banned
ATL, GA
a 5hp engine at redlined at 3600 rpm has as much torque as a 10hp engine redlined at 8000 rpm?
pretty much yes. torque is produced from displacement/weight of the piston. so a bigger piston at slower rpm will be the same torque as a lighter one at higher rpm.
if you've ever looked at the specs of industrial engines youll see that even though it has just 5hp it has about 7.3ft/lb of torque. and your engine has around 6.5ft/lb.
with that in mind i would still take the dirtbike engine any day. the built in tranny is what makes it better and higher rpm for a higher speed
