What do you think I should do?
That looks like a vert motor turned horizontal... Have you done the mods for proper lubrication distribution??..
If going with a cvt, what is the mounting plate going to bolt to, as there isn't the typical bolting pattern available being a converted motor?
Jdr72
Oxford, Maine
This is a converted motor I have welded up a new oil flicker and cut new grooves to allow the oil to drain. The motor does have a four hole pattern that I plan on adapting to fit the backplate whether it be by drilling new holes or using 1/8 in steel to fabricate a mount.
