I have a 24 hp linamar lx990 engine and I need a battery for the starter. I looked up the information online and got this about the battery:
STARTING SYSTEM
Nominal System Voltage: 12
Maximum Total Battery
Cable Resistance: 0.002 Ohm
Battery Recommendation for
Starting (with recommended
engine oil and no parasitic loads)
Starter Solenoid:
Minimum Pull-In Volts: 8
Minimum Hold-In Volts: 8
Nominal Pull-In Amps: 33
Nominal Hold-In Amps: 7
I got it from this link - http://www.continentalengines.com/pdf_files/linamar_lx990.pdf
I understand I need a 12 volt battery, but I looked at some previous thread about someone with a 11 hp engine and apparently not all 12v are the same.
If someone could let me know what kind of battery I need I would really appreciate it!
Thanks in advance!
STARTING SYSTEM
Starter Solenoid:
Thanks in advance!
