actually a good idea to take some pyrometer samples if you own one.
Surely doesn't hurt to know what temperatures you are actually dealing with.
(well get a good idea of the temps.. since I doubt you're willing to properly calibrate it )
Anywhoo.. also: please add a load measurement..
cold unused for hours,
then 30seconds up the steepest incline you can find and promptly measure again.
(ideally the wedged inbetween packs, not the top ones)
Also: if you series wired just four (as you stated iabove)
you are up for 96A continuous not 180A. (only if you wired both sets in parallel 180 is a viable continuous draw..)
Since you'll need roughly 42Amps max (if geared properly) not to mention nasty peaks...
that's about 50% of the allowed continuous discharge thumbsup
with just four of the packs... a good safety margin IYAM.
Still temperatures are better be checked.
if you can run a fully charged set dry (well till the controller triggers undervoltage protection)
as quick as you can (10mins or such)
very little chance the batterypacks will ever see more discharge abuse
(as long as you do not increase capacity of course)
that raise in temperature should therefor be about the maximum as well.
and with that you can feel reasonably safe IMHO.
PS I'm still for velcros instead of cutout foam to hold the packs in place...
but that's just me
but that's just me
