What axle.
r_chez_08
Should be in the shop...
Cornwall, UK
The bearings have built in set screws that act like lock collars.
When you say chain sprocket, what do you mean? The chain, sprocket, or both. Also do you want hubs for the sprocket? They are about 16 euros of the top of my head.
Would you want any brake stuff?
Edit: 77mm is probably 3", which is 76.2mm
Rob
ibrahim123
then its probably 3''. sorry what i meant was a hub for the sprocket. id like that aswell. i wont be needing the collars. When can u order these things and how are we going to arrange payment so that there is no risk of me losing my money or you not recieving the money?
r_chez_08
Cornwall, UK
Ok. No sprockets/ chain/ brake stuff then?
We could use paypal, that would be the easiest way. I will order whenever you want.
Shall i get some keystock too?
Btw the sprocket hub is 6 bolt designed for 6 bolt sprockets. I dunno how many holes your sprockets have, but if different, i think ebay have different ones.
Rob
ibrahim123
Order them ASAP. There is some problem with my Visa atm and i will have to go to the bank to get it fixed and also put money to send it to you. Im going to do this on Tuesday when banks open since it is easter here in Cyprus and everything is closed. Is it possible for you to order them and when i get my card fixed send you the money so we dont waste any time? If not then we can just do it on Tuesday when im ready.
To make things clear we are getting: A 110cm, 3cm axle, the hubs (if they match to my rims), 2 bearings and the hub sprocket. Can u order a sprocket hub which is most commonly used by people so i can easily find sprockets from where i live. I was thinking of also ordering a sprocket but what if it does not give enough torque?
ibrahim123
Edit
Yes i would like the key-stock for the axle + can u link me the sprocket hub so i can take a look at it and also maybe search for a sprocket which will match it so i can tell you which one to order as well. Thanks man :)
r_chez_08
Cornwall, UK
The axle is 102cm. Is that ok? I will order when you comfirm the length, as i dont want to get it wrong. I guess i could always make you a custom longer axle if you needed one longer, from mild steel. Of course it would probably take me a bit of time, so it may cost more.
Rob
Edit: for the sprocket it would e nice to know what size wheels and what engine you are using. Do you need a clutch?
Edit2: also just thought that i could make you a rear sprocket for material cost, as i have access to a cnc cutter, and i always have been meaning to try and cut a sprocket on it. Material would probably be under €10.
ibrahim123
Order me the axle, the bearings, the hubs (ill drill the holes on the rims but hopefully they wont become weAker because of that. Get me the hub sprocket as well and you can also make me the sprocket since it wont cost much. So basically u are ordering everything
ibrahim123
Edit
The sprocket could be as big becuase the rims are 8 inches diametre + more length from the tire. Dont make it too big though. The engine is a motorcycle engine 200 cc, manual. The teeth should be enough for the engine to give good torque. You decide how many teeth :)
r_chez_08
Cornwall, UK
Ok, i will make you a sprocket, but how many teeth are on the engine? Also do you know what the max rpm of your engine is, what pitch chain you are using (can you get chain?) and what hp your engine is.
Btw i cannot 100% guarantee the sprocket will last, but for 10€ its pretty cheap anyway.
Rob
r_chez_08
Cornwall, UK
Hi,
Ordered
1x axle, 30mm x 1020 with 6mm keyway
1x 12" key steel, 6mm
2x pillow blocks, 30mm
1x sprocket hub, to fit sprocket i will make.
I havent ordered the hubs for the wheels yet because i have found a hub with a 3 bolt pattern, that is 78mm, and 22mm bore which i could drill and put a ketway to make it 30mm.
I will wait for the reply of the other one first though.
Rob
r_chez_08
Cornwall, UK
Haha sorry we posted at exacly the same time so i didnt read it. Mine is pastybloater@hotmail.com, but im hardly ever online.
However shall we say we both go on at the same time? Were in different time zones though.
Rob
ibrahim123
Say in 30 minutes (if you read this post now). Check what time i posted and add 30 mins and ill be online. If your not online in less than 30 mins just say when u are.
r_chez_08
Cornwall, UK
I am usually online at about 9.30 pm, that is 3 hours from now, the time here now is 6.30pm, so you can work out when i will be on.
Still no news about the hubs, but i will wait till tomorrow as it is the bank holiday weekend
Rob
