What about torque specs on a torque converter
pgreen491
What can a 40 series take as far as torque, everywhere I read has horse power ratings but my engine is a 16hp clone with a few mods
pgreen491
Header, air filter advanced timing, billet flywheel, valve springs, gov. Removed, billet rod, bored and jetted carb, ported and milled head. But the engine is very torquey. Sorry for the caps my work system only works on caps
r_chez_08
Should be in the shop...
Cornwall, UK
8-18hp 4 stroke, but you should be ok up to 22 or so hp.
you are probably making close to 20hp.
r97
Measure twice cut once
Massachusetts, USA
Well since most of these engines run stock at 3600rpm a 22hp should make around 32ft-lbs of torque, I kinda doubt your engine will exceed that. A lot of your extra hp is probably from increased rpm anyhow right?
r_chez_08
Cornwall, UK
Yeah, if you look at the hp curve of a clone, it is still increasing after 3600 rpm, but they don't show it.
Surely if the hp is from higher rpm, it doesnt matter as much because the torque converter is already locked up?
