Header, air filter advanced timing, billet flywheel, valve springs, gov. Removed, billet rod, bored and jetted carb, ported and milled head. But the engine is very torquey. Sorry for the caps my work system only works on caps
Well since most of these engines run stock at 3600rpm a 22hp should make around 32ft-lbs of torque, I kinda doubt your engine will exceed that. A lot of your extra hp is probably from increased rpm anyhow right?
