West Bend 820 chainsaw?? kart??
ohpoppy
I am being offered a west bend 820 but I suspect it is a chainsaw engine. the model is 820?0 (can't make out thr 4th digit), and it is tagged Chrysler marine with the pentigon emblem. The carb is mounted on its end, not on top (are carbs able to be relocated??). Anyone know about these type of engines?? I have the serial number if anyone has resources in this regard. Thanks, Bob
KartFab
Dallas, TX
Bob. it might be best to post a bunch of pictures for a bunch of help.
No pictures may not be in your best interest. Click advanced, then the paper clip symbol.
Also, have you thought that perhaps west bend made 2 stroke engines, some of which were put on go karts? I haven't investigated this thoroughly, but even today, most yard go karts use generic engines meant for industrial applications.
Another thing to think about, is that regardless of it being 'authentic', how useful would a 50-60 yr old 2-stroke engine be? If you find value in it personally, that's great. But a lot of times, most old worn out engines are just old worn out engines, regardless of how awesome they once were.
a west bend 820...
like Mac10s likely the holy grail of vintage kart engines.
And yes.. they ARE two strokers (as the best kart engines always are ;))
This is an 820:
isn't it a beauty ...
Now, the carb manifold can enter the crankcase at the side* (as you see in the pic) or at the bottom* of the crankcase.
* stating the cylinder is on top of the crankcase, engine orientation doesn't matter here.
just a matter of which manifold is installed; as you can see, that particular engine has a dual carb manifold and even the scoop intake *grunt*
Anywhoo..
you're the lucky one that was offered a west bend 820..
do not be the dumb one who let that pass.
PS If you're not into vintage karts at all.. you can make your life easier and cheaper with a predator 212 alright...
but if you want to propell a kart from the 60s THAT engine is what you want!
PPS there's still a replica available new.. (cheaper than a used original)
http://www.usmotorpower.com/parts/replacement-engine
just to get you a pricerange...
tank destroyer
kannapolis,nc
back in the 60's when i was a kid i had a neighbor that raced go karts.i remember he had this engine on his kart.he had carbs on each mount.he used to run up and down the highway testing it out.it would do donuts on the asphalt with ease.
i remember he had a second mounting plate and he said he sometimes run twin engines.never saw his kart with twins on it though.
ohpoppy
I came to find out that since it was labeled Chrysler marine not Westbend it was 65 or newer. Many were used on snow mobiles in the 70's and 80's, by the serial # it likely is a newer one. The most powerful 820's were made for karts. The snow mobile engines were a bit less powerful, chainsaw engines were the least powerful. They also had many industrial applications. I would like to consider making my 64/65 kart period correct and use a kart engine. Mac engines are fully documented on MacBob's site as to the year of manufacture but West Bends are not as easy to track down, especially the smaller ones. I have the model #'s of kart engines that are 820's but can't find anything on the smaller ones. If anyone found a link to smaller WB identifation #'s, please post it here. If anyone has a reasonibly priced period correct 820 kart engine please contact me.
I discovered WB's are cheaper to buy and parts are more available. There is more flexabilty with mounts and clutches. They are also admired as much as Mac's but I prefer how the Mac's look.
To the guy that likes new engines, these 60 karts are antiques and are highly collectable. It's a matter of preferance whether one would prefer to drive a 55 Chevy Cameo or a new Ram. I prefer the Cameo.
I was impressed with a WestBend 700V-5, can hardly wait to run these 820.
good lord dual twin manifold ... four carbs on ONE cylinder ... that's AWESOME!!
(pointless as a flame decal.. but I want one :D... no not a flame decal :()
:thumbsup:
I wonder that 'get out flute' (I wouldn't call it exhaust really) it looks great and it sounds at least angry as 4377...
but I really wonder how much more one could gain with a proper calculated and calibrated pipe...
Bret? what do you say? care to fire up that calculator and punch in some numbers?
Desertduler
:thumbsup:
With the right pipe you can count on big gains as a tuned pipe for a two stroke is the single best enhancement that one can bolt on a two stroke for awesome power gains, I think I might still have a old 820 around at another garage of mine and if I do I will get it and see what it will take to freshen it up and I will make a pipe for it and test it out, I am soon going to retire so I will have a lot of time to myself to do things as I please. :thumbsup:
I keep putting them together. They were a big part of my youth.
well..
then you're likely one that could enlighten me a bit :D
those enduro tanks.. catch tanks or not?
anti splash or not?
since frankly they're really expensive considering they seem to be pretty straight forward and easy to replicate (once you can weld aluminium of course)
that I know (that's the obvious part);
the question remains: catch tank, labyrinth, anti splash or not ?
(so is there inside structure other than stiffening)
