supermanotorious
Winchmaster 5000
Ok, I'm not new to rectifier conversions in HF welders. But this machine threw me a curve ball. Instead of the stranded wire coming from the transformer, they are solid wires! Well I got the rectifier installed. I did test welds before I started to make sure I didn't have a defective machine on my hands. Now with the rectifier installed, the wire feed motor seems to intermittently cut out, then come back on as the trigger is held. The motor gets its power from the transformer, the wires are connected to the welding lead outputs. I relocated them to the AC terminals on the rectifier since they've been running on AC. I have had issues in the past with the gun trigger not maintaining a consistent contact but do you think this could be due to the rectifier somehow?
