Weird spark issue.
Sti1471
I purchased a used off road go kart the other day. The engine is a 150cc GY6. I recently purchased a new rectifier, cdi, and electric choke for it. I installed those items and all is good. I started the engine this morning and noticed something weird. The engine starts and runs, how ever i noticed that while it is running, the rear chain has sparks jumping between the links. Only place i notice sparks. I checked ask the connections i could find and they all look fine. Made site the spark plug boot was on tight. I am kind of stumped. Any ideas would be great
Bwdeaton
Dayton, Ohio
If the chain is sparking then I doubt your engine is grounded to the frame and the spark is traveling out of the way to get it to run. Just add a wire between a bolt on the motor and a bolt on the frame to ground it safely.
carefull..
before you add any wiring, check the existing wiring at least twice ...
ask someone to also check the wiring (get the wiring diagram for your engine)
In case you swapped two wires by accident you could burn through your new CDI again
Yes, chances are it's just a bad ground connection.. but then again, electric fault can occur in one place and show in a totally different place later ;)
