Weight capacity of my engine
jimmithy_james
Hi,
I've pulled apart a spare mower, a pope spitfire 40 push mower , with a 99cc 4 stroke engine in it. I'm trying to figure out the max weight my kart could be before it started pulling the speed down?
Thanks,
fowler
Bullsbrook West Aus
U can use a chain saw to move a tank
Its all about gearing
But a chainsaw tank will be very slow
Unfortunately 99cc is quite small
So reguardless of the weight it wont be cery fast
But if u keep it as small and as simple as possible
then it should work
Every single gramm will make the engine slower,
so as fowler said.. geared correctly and on a lightweight kart it will work,
and that means both, gearing and weight should be as low as possible.
Do not add lights, no second seat (or worse... passenger) no cooler or picnic basket..
no full suspension, no roll cage etc.
with 99cc 4 stroke engine (assuming ~2-3HP) you should gear a ~90lbs kart (empty) around 6:1
that is if you're not over 160lbs...
otherwise 7:1 or even 8:1 would be a better idea.
a 99cc two stroke can be pretty lame and pretty mean (not at the same time though ;))
so it'd be hard to assume output power.. but from 2-25 HP anything is possible
(a mower is of course closer to two than twenty;))
I think 15mph could be possible with just 3 HP.
PS if you really want to figure out the limits..
check my electric motors thread there's some math in there that'll let you calculate the needed power for a certain task.
