builder bob
I have a homelite sx135 bandit weed eater engine that i'm going to use for an r/c boat. it sometimes runs but only if I fiddle with the mix screws and then it'll only run a minut before it dies. I don't know which screw is which. it's a zama carb 'cause I haven't found a walbro yet. the engine has a new spark plug, makes a spark, has good compression, gets gas, and the muffler isn't plugged up. what is the specific function of the two screws (which is low end and which is the main mix)?
also how can I make the fuel line connecters on the carb a little bigger so the lines from the fuel bag stop leaking there?
