Amped
I got this Honda GX340 for $1 because it was locked up.
Turned out to be full of water. The sludge that was in it looked more like something from baby diper than an engine.
The linkage is barley there. You can see how it was rigged for a direct throttle . I'll totally do away with the linkage anyway so no worries . The governor linkage arm on this engine has a tab where it bolts to the governor stud (or whatever its called ) the is perfect for direct throttle connection
I removed all of the tins . The flywheel and coil have good coat of surface rust . The coil works though . I'll just give them both a light sanding when I start the rebuild. The cooling fan looks good as well.
The exhaust is done for. I'll have to replace the mounting studs as well. Never had to do that before. How hard is that going to be?
