I understand that someone that knows how engines work could just unplug a terminal and ride it. But if I put the key inline with the kill switch and soldered the terminals that will do what I want correct?
scissors, knife... teeth, a strong pull...
that killswitch (it's likely just your low oil sensor, right?)
I mean how many ways you can think of to disrupt a wire?
Many people know how the killswitch works,
frankly.. most do that care about karts or small engines at least a bit.
Those will not be stopped with a setup like that.
Sure the remaining few you can get rid of, but those wouldn't have touched your kart in the first place.
IMHO you're better off just buying a steering wheel with quick connect,
and removing the steeringwheel from the kart.
Sure thy can start the kart.. but where's the fun in that if you cannot drive it?
PS bicycle chain? just sayin'
