In all seriousness, I once saw Jesse James create extension panels for a Toyota Celica by folding a sheet then walked along it to create a perfectly contoured shape...
If you have a sheet metal folder, it's easy. If you don't, two lengths of angle clamped together will work to create a straight(ish) bend. After you've made the folds, simply wrap it around a large pipe
What Iwould do/try is getting a piece of 4x4 or 4x6 and shape it ,round it to meet your panel needs. Use a grinder to cut away the heavy stuff and a chisel,small grinder, ect to shape the rib. Sand everythingsmooth like for a f'glass mold. Then using a little "heat" and body hammers, start shaping the panel around the buck ,from the bottom up. With the workyou've done already,I have NO doubt you can do it ..... And like sid said,it would be handy to have to fix any mis haps down the road.....
You make it look easy though!
You tell me NOW? With all the "art" I've done I'd be rich by now.
