I'm modifying the existing frame. The subframe will reduce the overhang and produce a symmetrical chassis. I think this is the easiest way for me to perform the mod.
Ok, now I'm confused, are you modding the existing frame or simply adding a new rectangle frame to the top of it?
10" is my initial guess and is not written in stone. Currently I have a 66T, which OD is just 7 1/4". 72T OD is less than 9". I'll take your and Half-Breeder advise into consideration. Thanks!
One thing Tihm didn't mention, you may have enough space within the frame to fit the sprocket & a brake disc, you may have enough width to hold the engine BUT, where does the chain run in relation to the front end of the frame?
