Denny Graham
Just finished up a my Alley Kat copy last month and.....well, it's really twitchy!!!! As ya'll know, once the
welds are made on one of these, you're pretty limited as far as front end alignment goes. I set it up with
7° KPI and 7° Caster, toe in is the only thing that's adjustable on these old style karts, and that's about
1/16" to 1/8". I've got about 60-70 yards of straight drive before I have to shut it down and from a dead
stop I'm getting it up to 48-50 km/h (that's around 30mph) before I have to brake. At that speed it really
is quite....twitchy..... is the best way I can describe it.
There us no slop in the steering set up, has brass bushings, i.e., in the steering shaft
and king pins. New brgs in the front wheels with new vintage 4.10x3.5-5 slicks.
Using the typical pitman arm set up with tie rods swinging on a 2 1/2" arc.
This kart has the tie rods out in the front porch so Ackermann is not possible. (wish it were),
and that has me wondering if that might be the problem
Next one will have the tie rods behind the axle so I can build in Ackerman!!!!
Any ideas, examples or similar experience with this type of kart and this type of steering set up???
Denny G
Sandwich, IL
Denny G
Sandwich, IL
