It was described as a 60's rupp but can't find any pictures that came with the tri star wheels. Most have the turbine wheels and the tri stars came with this kart.I'd attempt to try lifting any information possible off what appears to be an emblem on that nose cover.
Easily done if it's embossed, not so much if it's printed because then you can't use solvents to remove the paint from it... you have to use heat and hope the paint doesn't pull the print if there was anything left before the paint went on.
Check under the seat for an ID tag as well, the seat itself screams 60's because the 70's tuck n roll stitches seats were different.
There's a few it "LOOKS LIKE" it could be, but its a short list and none are exact...It was described as a 60's rupp but can't find any pictures that came with the tri star wheels. Most have the turbine wheels and the tri stars came with this kart.
Not mine but interested.
Can't find a Rupp picture with the tristar wheels though.
Those are McCulloch kart wheelsI got some pictures and info now. That was the only picture I had that a friend sent to me. 60's Rupp Dart is what he was told.
