hey guys its been a while. Anyhow I was at the junk yard and saw what appeared to be an 8HP briggs horizontal L head and popped on it for only six bux. The only missing parts appeared at the time to be the carburetor.
Since then i have torn it apart and decoded the model numbers to find out that it is really a 1965 6 HP Horizontal Shaft Engine. It was governed for 4000RPM at the factory and is equiped with an air vane governor, just like the ones on a lawnmower carb. The engine is in excellent shape aside from the fact im missing
-fuel tank (this one is rusted throught)
-Intake (Carb,air box,governor)
-Broken 3/4" pipe in exhaust.
so my question is, would this engine be worth a resto-job? or modified for a kart? I know this engine also has a MUCH longer stroke than most engines of its size. If its not worth a rresto-job i was considering making an intake setup for it using a 5hp carb
