victa electronic igniton
mattbrown98
Queensland
im puttin an electronic ignition module or running a total loss ignition systme in a 125 victa any wire diagrams and what parts i do and dont use s ones i have the parts i can start and get it finnished. any help will be apreciated
cheers matt
cheers matt
What are you asking? It is hard to understand what you have written
ak99
Queensland, Australia
If you're buying the ignition module it will come with an instruction sheet on how to fit. Very easy, basically it takes the place of the points & condenser. You still use your existing coil.
mattbrown98
Queensland
thanks
i was trying to say i am thinking of using a ignition moduel to replace the points and condenser
or run a total loss ingnition circuit eg hooking points up an external battery and ignition coil
and was just wondering what parts i need or dont need for either of these two setups
sideways
Unfinished projects king.
Perth, Western Australia
As ak99 says, the ignition modules come with instructions. You just hook them up to the points wire and you're done.
This will be as cheap as you will find.
http://www.ebay.com.au/itm/ELECTRON...wnmowerAccessories&hash=item20d36238e9&_uhb=1
For the total loss system you use the coil from a points ignition car a motor bike and wire it up as you would on anything else.
There's not really much advantage to running the electronic ignition module other than having a no maintenance ignition system. It should run better than with the points but you'l probably notice no difference.
The total loss system will eliminate the rev limit and let the motor motor rev until or runs out of power or the flywheel explodes.
sideways
Here's the instructions that came with mine.
mattbrown98
Queensland
will the ignition module remove the rev limiting
also will the points that are already in the engine work for the total loss circuit ?
i hope it runs out of power first haha
ak99
The module won't remove the rev limiting, to do that you would need to go the car coil route.
I've never done this, however I'm sure Sideways would be able to assist.
mattbrown98
Queensland
car coil route it is then i may aswell go all out on it and see what happens when i put it on my kart as long as what happens isnt a flywheel explosion or destroying the motor all will be fine
sideways
I doubt the motor would have enough top end power to get fast enough to grenade the flywheel. You'd need to do a lot of work for that. Watch those revs though. I remember reading about a 125 flywheel that died at 11k rpm, there's a million different types of 125 flywheel so certainly don't take that as gospel.
From what I've read, back in the day they used setups similar to the inner rotor kits pit bike guys use. Adapted from Villiers motors of some kind. This negates the whole flywheel explodey thing by simply not having a fly wheel. You don't need one on a direct drive vehicle. They were doing it primarily to get rid of all that rotating mass though.
mattbrown98
Queensland
as far as flywheel explosion goes what if i used a flywheel of a 2 stroke motor bike iff one would fit shurely it would handel high revs and be much safer its not going to have the shroud over the engine so there is not much point in having fins on the flywheel and its going to have a cent clutch drive
The chance that another flywheel would be compatible is pretty slim, especially off a bike
sideways
I think the ultimate solution would be to adapt the stator, flywheel and CDI pickup from a 2 stroke scooter. That way you get a proper ignition curve, no rev limit, a charging system and a non-explodey flywheel with a cooling fan on it. Of course, this would require some machining.
mattbrown98
Queensland
ill still give it a shot if it dosnt work it dosnt work ive got automotives tomorrow ill ask the teacher if he has any old victas in the shed that i can have
for the total loss circuit the original coil is eliminated so it would not matter if the magnets were in a different place aslong as the new flywheel fit the shaft and does not hit any thing
mattbrown98
Queensland
sideways i have all those parts off a dt 175 i may be abel to get it all to fit that way all the circuitry is already done and on the kart frame the 175 was originally on the cart till i killed it
sideways
You could just remove the flywheel all together.
If the DT175 is a CDI one I'd adapt it's ignition system too. A fixed advance points system isn't ideal.
If your kart is setup for a DT175 then I'd find another DT175 motor for it. It's not like they're rare or valuable or anything. A Victa wont come close to the performance of the DT175.
mattbrown98
Queensland
thats true i just like the idea of messing around with a victa cause they are much simpler to pull appart and work on than a motor bike engine also i have no where really to go fast on its more just something to show my mates when they come out mess around for a bit if i could find another dt175 laying arround for cheap id get it
