Victa Decompressor Control Mod
jman231994
Australia
Hi everyone,
I've been thinking about this since i tried starting my victa with a spark plug in the decompressor hole. Does anyone who has a knowledge of carbs or more particularly the victa carbs, think it would be possible to make a spacer with a plug on it for the decompressor line to go into?
I took a look at my plastic g4 carb and it has a small hole on the inside of the carb where it mounts to the engine. The decompressor hose attaches to the other end of the hole on a plug on the exterior of the carb. I think if i made a spacer to mount directly to the engine and with the proper mounting holes for my good carb it might actuate the decompressor valve.
I can start it without the decompressor but it is slowly filing down the starter cup from the extra force on it :S
Thanks
sideways
Unfinished projects king.
Perth, Western Australia
The decompresser valve needs vacuum to close, it'l normally close with the vacuum pipe disconnected anyway though.
Just fill the little fitting that the pipe connected to with a fuel proof silicone.
IMO the best mod you can make to a Victa is getting rid of the G4, the best bet is to get a G3 carb because they just bolt right up, pretty much double your HP.
If the pawls are rubbing on the starter cup then you need to clean out the little mechanism. You'l see there's some bits that rely on friction to work and other that need to slide, grease appropriately.
Get a new set of piston rings if you can, Victas normally have really worn rings, every single one I've stripped down had at least a 5mm ring gap! :eek: Again, a double your horse power type thing .
Good luck with your Victa mate, they can be a bit "fun" to start with no decomp and no blades hay! :thumbsup:
Post some pictures of it! From you description I'm guessing it's a points ignition full crank? Probably a series 70 MK 3 or 4?
If you need help finding adapters for the crank let me know. :thumbsup:
Welcome to the forum. :thumbsup:
Thanks
Hayden
jman231994
Australia
Thanks for the quick reply.
I'm hoping there will be enough vacumn seal from the new carb ive got to shut the valve, thats the idea for the spacer piece with the pipe fitting.
I plan on getting rid of the g4 asap haha. I had a choice between a g3 and a g4 but the mower that the g3 was on was in really poor condition and the starter seemed stuffed. So i went with the other cause ive got a briggs carb to replace it, just like brendonv's if you have seen his one. Its on here somewhere.
I think i got lucky with my engine. The compression is quite good and it had a good spark. Although i may give it a rebuild and port the inlet one day. I got degreaser and water under the flywheel when i was cleaning the gunk off it though and it fried the condensor. $15 later and it was working fine.
It's smokey but im hoping its cause my fuel is pretty old. Weird thing is it only started smoking once i put the new condenser in. Could be a better spark is burning the oil more and creating smoke.
I think when the starter is grabbing on the cup a bit of oil or something is making it slip. Hopefully easy to fix. New starter cups are pretty cheap anyway if it does wear out.
Ill get some good pictures up tomorrow when theres some light haha. And your right about the model. Its a MK 4. I know because it still had the original metal film sticker attached to the cowling. I think whoever owned it took real good care of it.
My plan is to get the original blade boss off the shaft and machine it down to 3/4" on my schools metal lathe. Havent worked out the other half of the adaptor yet.
Does anyone make them other than gaspares? Cause they seem to charge a fair bit for two little pieces of steel. I guess they probably only make small numbers of them cause not many people need them.
I've actually been a member since late 2009. Only remembered i had an account the other day when i really got back into my victa kart. Haha that pretty much means im still a new guy.
Thanks
sideways
Thanks
The vacuum from the new carb should be fine, the decomp valves usually just close by them selves anyway.
If you can, I'd grab that other mower, it's good to have spares, then you can experiment with porting and shaved heads ect too. :thumbsup: Briggs carb should be fine, it's a fair bit of work to fit them though, I imagine the jetting would be way out for a Victa too.
IMO all Victas seem to have really good compression, even the really worn out ones. Points Victas usually have dead condenser, yours was on the probably on the way out anyway. You can use the electronic ignition from a Power Torque or later full crank, if you want to do that then I can show you how to wire it?
As for the smoke, see my comment in the other thread, you could of accidentally changed then timing too.
Starters are usually very easy to fix, as I said, normally just a bit of dirt gets in there and jams it.
Cool, mark 4 and mark 3 are basically the same, just minor differences in the carb.
Good luck with machining the boss down, I've always wanted to try it but either didn't have access to a lathe or found better ways of doing it. The easiest way to get it off is to hit each side of it with a ball pein hammer. I have gotten them off with just a normal hammer and a lot of swearing though. The thread is 1/2" BSF and the taper is 15 degrees if that helps at all. What I do is get 1/2" pulleys and cut my own key way in the shaft. I don't really like centrifugal clutches to yeah. If you could find a 1/2" cent clutch you could just cut a key way in the shaft but one of those would be near impossible to find.
None that I know of, you can get the pulley off the bottom of a 24" cut Victa but other than those there are no off the shelf adapters/pulleys that I know of.
Thanks
Hayden
jman231994
Australia
Thanks for the good info.
As soon as i get my carb back off my friend ill see how it goes mounting on. My friend put the same type of carb on hers and it bolted straight on once the plastic mount was unscrewed. Just needed the metal flange broken off. Its annoying to have to break it, but i really want to get my kart moving.
Hopefully your right about the decompressor cause the things a pain to start without it.
I would go get another victa but i need to buy all my bearings and the clutch, sprocket and chain and i still need to find some good wheels that i can get onto my axle and still have sprocket clearance for off road. Got any ideas? I read that a 72 tooth is around 8.8 inches in diameter which rules out anything smaller than 12 inches really
Ive got an old powertorque electronic ignition module. One of the wires is broken at the unit though. I'll take a look to see if its salvageable. Does the ignition module provide any power increase? Or is it just easier to work with cause theres no points to misalign?
Ive heard its possible to get the boss off by putting it in a vice and tapping the end of the crankshaft so the whole engine comes out of the boss haha.
Once i go back to school i should have a heap more access to the tools i need to make some parts for it. The schools actually got a few victas in a cupboard i could take a look at if i forget measurements :p Theyre in pretty bad shape though. Broken flywheel blades and the like.
Thanks for the help
jman231994
Australia
I found the powertorque ignition unit. It wasnt broken at the unit. It had been sheared further down one of the cables and i couldnt be bothered to replace the plug on the end.
So, this means i have a fully functioning unit here to tinker with. As you said in an earlier post, you could instruct me how to wire up the unit to the full crank. That would be awesome if you could please.
Will it give extra power. I read somewhere that something like this will give more power over the stock setup. It wasnt a very definitive explanation though so it may be another part they were talking about
Thanks
