Vibration
Stevenf
Florida
I've got a manco go kart with a 7hp predator engine and a comet tc. The whole cart vibrates like crazy when I ride it. What might cause this? I've been running it on a smooth road around my house.
peterbilt
Denver,Co.
Or it may just be the engine showing it potential. I had a mini bike and when you sat on it it would give off crazy vibes to the point you felt as if you were sitting on a Harley.
It could be loose engine bolts, cracked frame or engine mount, damaged flywheel making it unbalanced. You could put some rubber cutouts between the engine and the mount and tighten it down. Just make sure it is tight, cos the nuts can come loose
gvfc2
wishing i was living
Tacoma,wa
also make sure the rubber isnt that thick. the engine could shift and might throw a chain
