Vertical Engine go kart/minibike questions
r97
Measure twice cut once
Massachusetts, USA
ive thought of doing that belt setup with the two idler pullies but knew it wouldnt work because v belts dont bend side ways. but i didnt know about these hex belts, id be interested to see if it works. martin sprocket and gear sells sprockets but i cant find a distributor. and snow blower auger gear boxes may work im pretty shure they have 1 to 6 rateo
fowler
Bullsbrook West Aus
not everyone has access to a milling machine.
i dont have one either
why do u need a milling machine
just weld / bolt the gears onto a shtaf or plate with shaft then put the shaft though 2 bearings
do that twice one going to the clutch and engine other going via chain to axil
in terms of lub
either fit a grease nipple or put the whole system in a bok and half fill it with oil (all the way and it will leak from the bearings)
the horisintal gear will throw the oil up to the vertical gear
made a pic (sorry im shocking at anything made on a computer)
and turns out blue oil is best
