vertical crank shafts
BearClaws
forr those who want a vertica crank shaft , you can buy a gear box that either tranfers power 90 degrees or a gear box that has 1 input and 2 out put shafts and turn your cart in to a postrac configuration. a good thing to is that you can have it so the out put ratio is higher than the input ratio , they come in many ratios. hope this helps someone smiles
:eek:ut:
