Vertical conversion Running
thats a lot of work for a dremel tool. I would try an air powered die grinder/cutoff tool or an angle grinder, these have more give to them and they can work harder than the dremel. One blade on the grinders will save u a whole lot of blades on the dremel as they are expensive and stronger comparatively.
robbie
Osceola, Missouri
When I first started using a Dremel tool I always got the thin grinding discs. Later I found out they sell another disc that's twice as thick. They last a lot longer.
Although I prefer using good tools, I like to remember that people used to have a lot of really impressive skills back in the old days, before you could pop into Harbor Freight and buy a metal lathe or milling machine. My brother in law has some tools handed down from his great great grandfather, who moved to Ohio from Germany in the 1800s. He was a clock maker. One of the tools is a table saw, which he built himself. It's about half the size of a two-slice toaster. He cut out the wooden parts to build the saw, which would then cut nicely mitered pieces for clocks. Judging from his work on the table saw, I think he could have made perfect clocks without it, but he built the saw to speed production. The saw was powered by a small steam engine, which he also built. I've seen the steam engine, but I'm pretty sure it went to another one of the brothers in my brother in law's family.
Clayton
Saskatchewan, Canada
Would you have to deepen the key way if you brought the shaft down to 3/4''? I am asking casue I have a 3hp briggs that I converted, and wanna use.
