Valve/timing issue
at TDC the t should be right inline with the "useless" tab in the crank case, that's actually a pointer :D
Please take some more pictures, or even better a video (uploaded to yt)
to see what you got, and what it does (or doesn't)
maybe we can help
Mrenglish90
Ocala fl
I further inspected and broke it down after it started doing that.
The head looks fine and undamaged, and the valves are moving up and down properly, the spark plug is in snug, and it is still timed properly as well....
What else is there to check when dealing with compression?
You think it could be the piston rings?
second video sounds like there is absolutely NO compression at all!
You sure you have the head gasket in?
and the spark plug?
Maybe you forgot the piston rings?
*shrugs*
