valve spring lbs, whats best
ringrace
on a clone or gx200 /160 what constitutes using a heavier valve spring than the stock 10.8. if the gov is still attached is anything heavier necessary. at what point in the modding process is a 18 lb, or 26 lb spring necessary/recommended
not even if you removed the governor.
the heavier springs only prevent the valve flutter
(which happens at around 5200-5500 rpm with stock springs)
that flutter is indeed a good thing to stop you from overrevving a unmodded engine
(and with that I mean [stronger] billet internals .. not a shiny exhaust)
18lbs springs increase the valve agility to around 7000-7500 rpm;
26lbs beyond that... but rarely ever usefull (other than for open clone racing)
you won't reach that kind of rpm without throwing hundreds and hundreds of bucks at the engine,
enough to just buy a way more powerfull enigne in the first place ;)
