Valve shims
Kleyny
Brisbane Australia
Looking at adding valve shims to up the stock pressure a little bit. Will this lift my revs up?
I'm getting valve float at 5000. Would love to get up around the 5500.
I'm not interest in 18lb ones as I'm only looking at 5500, once again due to me being in Australia I cant find heavy duty 10.8 here and the shipping is an absolute joke for a 2 valve springs from the states.
Any ideas on roughly how thick I can go with a stock GX200 before spring bind? Obviously I will be checking for binding but would like a good starting point.
Thanks
The thing that has been mentioned earlier, that if you are running a stock rod, then you want valve float... Your kinda approaching the threshold of the rod in rpm's.
Kleyny
Brisbane Australia
Would you believe I changed what I was googling and found these shops not long after I posted. There is another kart shop in Brisbane but he doesn't have 10.8lb springs.
Thanks
---------- Post added at 06:33 AM ---------- Previous post was at 06:29 AM ----------
I like living on the edge, well on the safe side of the edge anyway :thumbsup:. From all my reading over 6k is not good for the stock rod. I'm hoping 500 under and not for long periods will be ok.
My track is fairly tight and there is only two spots where you get up in that range before you have to back off again.
mckutzy is genrally correct on that one..
No spring upgrade with stock internals..
but since 10.8 is just a hair over the original stock GX200 springs;
AFAIR it's basically what Honda sells as a replacement spring for certain [older] GX200 models themselves.,
those will still not rev past 5.5-6k rpm, and that should be good for all GX internals.
"should".. if they're not, you're on your own, everything you do you are responsible for yourself ;)
I guess he just missed the target rpm you're trying to hit ;)
Kleyny
Brisbane Australia
That's pretty much what I have read. I'll be changing the oil regularly to keep the internals the best they can be.
And it's a lot easier to persuade the minister of war and finance to get performance parts if it's broken:lolgoku:
Hopefully if it does let go it doesn't damage the block.
