I have a 440 Duromax that I’m doing a little engine work on. Billet, cam, rocker arms. When I took the head apart to put stiffer valve springs in I was surprised by a couple things.
1. No valve seals. I doubt that’s a big deal.
2. The valve stems on this big block are 5.5 mm where all other big blocks use 6.5 mm.
The big block likes valve springs in the 50-65 lb range. I need to go with stainless 6.5 mm valves.
So I need to pull the old 5.5 mm valve guides and put in new Bronze 6.5 mm guides.
I’ve done this on automotive stuff with special tools.
Has anyone done this on the small and big block clone type engines? What do I need?
Thanks, Bob
Thanks, Bob
