valve float?
ipwnr
toronto ontario
ok so i got a honda gx 240 nd im going to remove the governor and i know the valves will start to float at 4500-5000 rpm so can i use that to stop my engine from over reving or do i need new springs because 4500 rpm's is good enough for me.
Bluethunder3320
the valves do float at around 5,500 i believe. i revved the crap out of a 6.5 clone with no other mods and it held up....
here on DIY we dont stress the use of a billet rod or flywheel as being essential with little or no other mods.
one thing you might want to experiment with is the throttle stop screw and governor springs..... because once the governor comes out, it usually never goes back in.... you dont have to break the parts of course but usually they just dont go back.
