utility tractor transmission question
robbie
Osceola, Missouri
I want to build a utility tractor to pull a wagon on my farm. It will be used to haul dead pigs for butchering, watermelons, hay, firewood, rocks, etc. I'm aiming for a maximum gross weight of 500 to 600 pounds.
I could use one of the large expensive engines from Harbor Freight, but I won't be cutting grass and I won't be going fast with a load. I may build it with an alternate ratio selector for going moderately fast without a load, but that's still optional.
My question is about the transmission. I saw what happened to Chris's transmission when he put high-grip tires and extra horsepower on his tractor, so I'm cautious about using one. Should I avoid lawnmower transmissions entirely and simply use a Predator 212cc engine and a torque converter? It could drive a belt transmission to allow me to select high or low speed, and another selector to go in reverse.
exenos
Project Nut
If you used a peerless 820 or 900 series transaxle it will hold up to more power than you can reasonably throw at it. Also look into some of the older 3 speed hi/low transaxles, specifically one with a horizontal input. Most were in garden tractors and were made to handle plenty of power and very heavy loads. The one I have came attached to a 18hp engine and it's approaching the size of a transfer case. If you can find something like that I don't think you'll have any problems at all.
loud1
Fat Guy On a Little Bike
St. Louis, MO
You can check out surplscenter.com they have a lot of transmissions to choose from or at least get info about.
You can always look into making a Mini-Beep.
It was a 900 series that I shattered. The 820's are supposed to be pretty strong. That said-
I am already planning my next utility tractor thingy, MULEII. Plans call for a Peerless 700 transmission (NOT transaxle) and a live axle, likely 1 1/4" solid shaft, no diff. What you do not have, you cannot break.
Also- I did not add any appreciable power. I am running a 15hp OHV Briggs single in MULE, it shipped with a 12hp engine. These transaxle come shipped behind larger engines still. The problem was not in the torque, or the traction. It was in a bad bounce that caused a hard shock load on the right side of the housing. An axle truss would likely have prevented it. I am planning on building a truss for MULE.
robbie
Osceola, Missouri
So, the failure was in your frame, not the axle itself. That makes sense.
When I was a kid we had an old Montgomery Wards garden tractor with a 14 hp Briggs and a long drive shaft mounted to the engine. It went back to the transaxle, which had a car-style gear shift lever. There are a couple of old tractors in the scrap yard with this kind of arrangement, which would be a lot easier than building an entirely new tractor. The transmission would be so strong I wouldn't ever have to worry about breaking it.
Yes, and no. The frame would have tweaked a bit, but I also found what I am going to call an inherent weakness in the transaxle design.
And again- I believe the transaxle is to be generally avoided, in favour of a separate transmission and axle.
robbie
Osceola, Missouri
I think it would be pretty hard to crack one of those up. Next time I get a chance I'll go to the scrap yard and see what's there.
Have you ever considered building a small utility tractor with a rear axle from an old Corolla or Datsun? You could use a torque converter to drive a sprocket attached to the differential input.
Yes- and golf cart axles can be pretty stout, too. It's really a matter of what you can lay hands on, and what's going to best suit your purpose.
For MULEII- I am deliberately avoiding a differential for ultimate traction. With a solid live axle of say 1 1/4", and well-supported, I'm sure it will go the distance.
Nooo. Two. Two big snotty ATV tires, size and type currently unknown. I have a few possible options, and I'm even thinking about maybe duallies or a tandem, but that's for another thread.
Please- do keep me posted on this!
robbie
Osceola, Missouri
I will. I need to go anyway to get some parts for a riding mower. I've seen the old tractors over there before, but this time I'll take a closer look.
