CillerCrocCustoms
- Messages
- 15
- Reaction score
- 1
Hello everyone , I am looking to build a twin engine gokart which would use two Predator 212s. I know that you guys at DIY Gokarts are very knowledgeable when it came to prior posts I’ve had. And so I come to you once again for this question…
If I run the first 212 to the wheel through a torque converter to a sprocket wheel. Than I hook the second 212 to an opposite side sprocket wheel through a torque converter with a jackshaft added to the driven pulley and a sprocket going down to the sprocket wheel. Would this work? Would it overrun the the first 212? Anything you know is appreciated, thank you!!
