You must remember that if your governor is not removed, you are going to be limited to 3600rpm, so even if your tyre is free spinning, you are not going to blow the engine up.
well i backed the throttle screw out and itll hit 4500 w/ gov under no load. but when you run an engine under no load, the torque from the piston is applied to the crankshaft which deflects. the deflecting causes excessive vibration which the crankshaft cant take. look up torsional vibration when you're bored.
anyhoww, i decided to keep it simple and get some belts for the hand sander. i will find alternate uses for a go kart though haha.
