Upgrading/Repairing Old Carter Setup
f22a
I have an old Carter kart that I came across. The frame is in good shape, engine seems solid, but having some torque converter issues. I'm no small engine expert so I'm looking for some help:
Engine: Tecumseh OHH60 71223E
Drivetrain: Appears to be an old symmetrical MaxTorque setup (has MAX TORQUE INBOARD stamped on driven pulley), inboard driven pulley. Belt is a 5/8 top width V belt, symmetrical.
Torque converter driver pulley is making a lot of noise, almost like rattling or clanking when it engages. Anyone have any ideas why? Also, the spacing between driver and driven is longer than the standard MaxTorque belts that are sold now, and none of them are 5/8 top width. Would I need to replace both pulleys to get this thing right?
Basically looking to see what I would need to make this right with off the shelf parts.
I know it's not fancy, just think my kids would really enjoy this thing. Thanks in advance.
the max torque TCs -for all I know- are as durable as the series 20 Comets (also symmetric)
an automotive belt like the one you have installed atm, is for sure the wrong choice.
rattling...
check the driver clutch internals, should be a set of two shoes compressed by two garter springs;
unhook the spring ends and see if they snap back straight, if not and/or the weights look worn down excessively;
call maxtorque for replacement parts
they can also tell you which exact belt you'll need and where to get one
f22a
Thanks. The belt is definitely wrong, it is what was on there when I acquired it. It is an automotive belt. Could it be that the driver is rattling because the belt width isn't 3/4" like it should be?
I deleted that part, since I cannot confirm (for myself) that it indeed is 3/4" as the comet 20 as I think it was (sometimes even my memory doesn't serve me well ;))
Sooo... do not rely on that!
Ask Maxtorque, they will know for sure; rattling can be caused by the wrong belt, but I think only if it's much too loose and the movable sheave has room to wiggle around;
from the pic, that doesn't seem to be the case though.
you should inspect the driver, it's really easy actually..
just remove the bolt and take it apart; except for the garter springs there is not a single part preloaded or under tension; no rocket science involved ;)
Make sure everything is perfectly clean and a non interfering but still tight fit;
before reassembly, drylube (yes DRY!) the clover hub and the inside of the outer bell;
maybe the weights themselves if you wish, but nothing else.
If you're unsure if a part needs to be replaced, just take a good quality pic and show us.
f22a
Thanks a ton for the response and info. I can wiggle the sheave with my finger and almost duplicate the noise. It rattles most when the throttle is opened, once it grabs it sounds normal. I think I'll start with the belt and cleaning/dry lubing the converter while it's apart.
I'll call MaxTorque and see what they have to say. I'll post up the results here in case anyone wants to know.
f22a
What is the best way to keep these small engines from turning when you're trying to break the clutch bolt?
an impact wrench..
they turn fast enough to use the engines inertia (so no need to "lock" the engine)
similar (more neandertal ;)) place your wrench on the bolt and hold it at the bolt, whack the handle with a mallet.
if that fails... you need to lock the engine I'm afraid; easiest way is to remove the spark plug and insert a good amount of COTTON rope (not nylon or other plastics that is)
and if enough rope's in.. the piston will not reach TDC and lock the engine...
when you're done, remove the rope and reinstall the spark plug.
f22a
Thanks for all the help, Sid. I spoke with MaxTorque today and it was informative. They confirmed our suspicions somewhat that the improperly sized belt could cause some ratting and clanking if the sheave had too much wiggle room. Based on our conversation he said that the belt would be the best place to start and agreed with Sid as far as inspecting and cleaning the driver unit.
He also said that the pure metal driven pulleys were not likely to fail and offered the part number of a Comet belt that would fit the 7" driven pulley with the center spacing I have. I think I'll order a new driver unit just in case and just keep it as bench stock if it's not needed. I'll post the results when I get it all done, and again I really appreciate the help.
