sse1478
Hello,
I'm going to upgrade my single seater go kart which came with a 5 hp Robin engine to a 13 hp Greyhound engine from Harbor Freight. My main concern is the torque converter which is a Comet 30 series (rated for a max of 8 hp). Considering that I am the primary driver, I was wondering if i could keep my existing torque converter if i was easy on the throttle i.e. not flooring the go kart when it is stopped etc. I was also wondering what the weak point in the torque converter is (the belt, driver, or the driven). Both shafts are 1 inch, but I am unaware if they are in the same x y position. Are their standards for the placement of engine shafts, or do the vary by engine seize and manufacturers? Any information would be greatly appreciated as I have never done anything like this before.
