What kind/size of snowblower and what hp is it currently?
Snow blowers can get complicated for engine swaps... Many of them use a second PTO off the camshaft (half speed and backwards rotation) to drive the wheels. Trying to work around that can end up costing more than it's worth. Even if it already uses the main crank PTO, you'll need to gear the wheels down more so your travel speed is still appropriate for snowblowing
And no, there isn't anything I've ever seen or heard of for what you're asking.
If your goal is a higher tip speed at the impeller, your best bet is to build for max power at ~4000 and use a taller gear ratio. you can eek a bit more out of the stock gov without much risk.
Personally, I think you'd want more torque than high rpms. Snow is heavy. Takes a lot of grunt to get it moving. For what a 212 and the aftermarket parts would cost you, you could put a bigger engine (maybe even a 420) on there, have more power, no bogging, electric start, headlights, and a whole lot less noise. That's a major bonus if you have neighbors.
