Update on the murray nitrox???
dboy
where the GO Kart paths are a plenty
Hi friends-
So I just wanted to post some updated pics and ask some questions?
After a minor weld and designed solid shaft by myself its coming together.
Today I ran the kill switch and ran the engine disappointed.
As you can see I have the Intek briggs 6.5 engine.
Got if from someone for 20.00 off a power washer.
Brought it home and only ran on half choke. Took apart carb and now it runs only on full choke. I did clean out the carb and the dirt in the bowl. I did not buy new gaskets though. When I first put it back together it ran fine no choke idled fine.
Also I had to plastic weld the leaks in the gas tank. Any idea what's up with the carb and how to really seal these tanks? I sealed it filled it with water for days no leaks, drained dried it and put gas in and now leaks again.
Should be a few weeks until I iron out these bugs and get the floor in and roll cage back on.
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Your gas tank is Probably got left out side lots.. Plastic like that gets brittle and cracks easily, you could fix all the leak's but it'll most likely crack again...
Why not buy a new Gas tank and save some time there fairly inexpensive new?
