Up size tires for more height?
FRD1952
I have a bar stool racing cart, and the sprocket in the rear sits about 1/4 inch off the ground. I would like to drive it thru the grass and not worry about small bumps like coming in the driveway.
The current tires are Dunlop RAM 8s in the front and 11 x 6.5 - 5, and in the rear are Firestones at 8 x 11.5 -6. They are all slick types and meant for the race track.
I would like more of a street/turf type tire, but no NOTHING about this type of vehicle other than it is fun to drive around the neighborhood.
Can anybody tell me what size tire, brand, etc. I can buy to raise me say another inch or 2 off the ground, and I could drive on the grass and street ? Where can I get them and what type of price should be expected. I need NOTHING to strong at all since I drive it about 5 miles a year and maybe 5 hours total a year...even used should be good I think ?
Thanks,
FRD
To throw things into perspective for you-
To gain 2" of ground clearance, you need a 4" taller tire. Simpy bolting on 4" larger tires will have a largely negative effect on your gear ratio- you are going to lose a lot of torque, and gain a fair bit of potential top end- and beat the wee out of your clutch. Three very undesirable things when riding offroad.
To safely accomplish this, you're going to have to regear, possibly requiring the installation of a jackshaft to achieve compound gear reduction.
FRD1952
Wow...lots more to think about Toystory. Maybe I will try to go 1 inch taller only, and this will still impact the gearing, torque, clutch, but not as much. As I said, I use it very little so hopefully the impact is not too bad ? Thanks Toystory....FRD
anderkart
Surprise Arizona USA
Hey FRD1952, welcome to the forum :thumbsup:
You should post how tall all your tires are now, and then also how many teeth your clutch gear and axle sprocket has.
So are you having a problem with the frame dragging and getting hung-up over bumps,
or are you just kinda worried about damaging the sprocket/chain while entering your driveway?
FRD1952
will have to check on teeth...
I will check on the teeth on the 2 sprockets, but YES, mostly I am concerned about the larger gear dragging/hitting on the bump coming into the drive and other small bumps in the road. So I would like to raise up the rear especially say 1-2 inches just for small bump clearance on the rear sprocket. I am not too concerned with anything else like speed, etc, but would NOT want to wreck the engine or clutch. Hopefully with VERY limited use (at most 2-3 hours total over the course of a year, and 90% just on the neighborhood roads), just changing the tires will make the adjustment I am looking for without serious damage to the drive train.
anderkart
Hoosier sells taller race tires that will fit your rims, but you could make your old race slicks a little taller by over-inflating them to 75lbs and setting them out in the hot sun for a few hours. Then cool them off with water and lower the air pressure to 20lbs before riding.
Or you could just install a pair of sprocket guards:--> http://www.out2win.com/catalog/sprkt_acc.html
They're all either a 2-piece design or have a split so you can easily install them w/o disassembling the axle.
They come in several sizes and would protect your sprocket and chain from contacting the ground:
(they also make it nearly impossible for your chain to ever fly off...)
FRD1952
Thanks
Sprocket guard is a good idea, and I will also check out Hoosier...thanks!
r_chez_08
Should be in the shop...
Cornwall, UK
Could you get less teeth on the clutch drum and bigger tyres or a smaller rear sproket? Pics would be cool.
Jeremiah
Less teeth. -2 teeth on clutch sprocket and -14 on axle sprocket would keep same ratio (that is if your ratio is already 7:1)
